AudiJunkie - thoughts on Redline 5w-40?
Old Sep 8, 2008 | 10:28 AM
pac1085's Avatar
Old Sep 8, 2008 | 11:02 AM
Silver Streakin''s Avatar
Member
Default I'm not Audi Junkie and I haven't stayed at a Holiday Inn Express last night, but it's a great oil
from the research that I've been doing since I want something better than the M1 5w40 TDT that I've been using (M1 0w40 before that). I did use Motul V300 Motorsport 5w40 and that was the best oil for lower engine temps, but it's $$$$. (Blackstone report in my PP)
I've been think either Elf/Total 5w40, Castrol Syntec 5w50, Shell Rotella 5w40, Pennzoil Plat 5w40 or the Redline 5w40 (and others, but these seems to be the top performers). So far, I think I'm going to use the Castrol Syntec 5w50 at my 115k oil change, which I just did the 110k with the M1 5w40 TDT since I still had some on the shelf along with a qt of M1 0w40 -- so that's what went in.
fwiw, Redline's Vis @ 100c cSt is 15.1 and anything above a 14 is good, imo.
the M1 5w40 TDT is 14.9<ul><li><a href="http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil1_Turbo_Diesel_Truck_5W-40.asp">http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil1_Turbo_Diesel_Truck_5W-40.asp</a</li></ul>
Old Sep 8, 2008 | 11:04 AM
mktbully's Avatar
How does Amsoil rate in comparison?
Old Sep 8, 2008 | 11:11 AM
Member
Default on par. the specs for the Amsoil Euro 5w40 are here:
<ul><li><a href="http://www.amsoil.com/storefront/afl.aspx">http://www.amsoil.com/storefront/afl.aspx</a</li></ul>
Old Sep 8, 2008 | 11:19 AM
Member
Default Castrol Syntec 5w40 and 5w50 here:
and you can see the 5w50 is 17.4 at 100 and exceeds the 5w40 standards that pass the VW502/505 tests. AND, it's on part with M1 pricing. So far, I can't find a reason not to use it over the others.<ul><li><a href="http://www.castrol.com/liveassets/bp_internet/castrol/castrol_usa/STAGING/local_assets/downloads/p,q/pds_syntec_usa.pdf">http://www.castrol.com/liveassets/bp_internet/castrol/castrol_usa/STAGING/local_assets/downloads/p,q/pds_syntec_
Old Sep 8, 2008 | 11:33 AM
Member
Default Shell Rotella T 5w40 here:
<a href="http://www.shell.com/home/Framework?siteId=rotella-en&FC2=/rotella-en/html/iwgen/leftnavs/zzz_lhn2_4_0.html&FC3=/rotella-en/html/iwgen/products/product_rotellasynth.html">Info</a>
Spec sheet:<ul><li><a href="http://www.sopus-staging.com/staging/ShellRotellaTSynthetic_TDS_v10.pdf">http://www.sopus-staging.com/staging/ShellRotellaTSynthetic_TDS_v10.pdf</a</li></ul>
Old Sep 8, 2008 | 11:46 AM
ski ya later's Avatar
Default LOL. yes it is a great oil, I have been using it for 40K now and my report from Blackstone says..
mine is the best looking report of any 1.8t they have seen.
Old Sep 8, 2008 | 11:51 AM
velosouljah's Avatar
Default Do you or anyone else know more about Valvoline Extreme Blue Full Syn 5W40?
I work with a lot of Diesel Truck Guys and they either swear by Rotella or this. I don't see any Gasoline ratings on this though like I do for the Shell Rotella T 5W40?
Old Sep 8, 2008 | 11:57 AM
Member
Would you mind scanning it and posting the report? I wish we had a database/list in teh FAQ.
Old Sep 8, 2008 | 12:02 PM
Member
Default Valvoline 5W40 here:
<ul><li><a href="http://www.valvoline.com/products/Synpower.pdf">http://www.valvoline.com/products/Synpower.pdf</a</li></ul>
