Auto Tranny fluid change
#21
This is the kit that has been referenced time and again here, available for $131.27:
:: www.ECStuning.com :: Now with EXTENDED Customer Service hours!! | FIND US ON FACEBOOK!!
Phone: 1.800.924.5172 - Sales: 8:30am to MIDNIGHT EST | Customer Service 8:30am - 8pm EST
Questions? PM us for a quick response! | Email: Pete@ecstuning.com
#22
+1 It behooves you to get everything as clean as possible - the surfaces the gasket contacts to ensure a proper seal, and everywhere else to ensure your new filter won't get quickly clogged up again. I am always pleased with the improved behavior of my transmission when I change it - you might not notice how bad it is until you change your fluid and have it back to shifting like butter. Besides, beats an early death to your transmission any day.
#23
Was having a hard time figuring this out until I looked at the back of the bottle, and yes, it's fully synthetic:
#24
thanks for the info.
#25
No worries! I'll be here if you have any further questions.
#26
Can someone shed some light on this subject? I'm in my garage right now refilling the trans 01V at the check/fill point in front of the pass side cv shaft. The tranny is empty and wont even go into gears, but when I pump fluid into it and spits right back out onto the ground like its full, but i did I pan drop and filter change. Am I better off finding a plumber fitting with a barb on it to fill with at least a couple quarts to warm it up and drive it?
any thoughts?
any thoughts?
#27
any thoughts?
any thoughts?
The transmission has two differentials that use gear oil, the front and center diffs (center is at the rear of the unit), and a center section that uses the ATF. You drained the ATF, but it sounds like you are trying to pump fluid into the front diff.
Suggest you attempt to suck out as much of the diff oil (there is no drain plug) at the front diff and refill with the correct gear oil. Then fill the ATF though the correct port in the trans pan.
Whatever you do, don't start the car until you get at a couple of liters of fluid into the trans, and don't try to drive it until you fill the trans.
Shame on you if this is a joke.
#28
I hope this is a spoof, but I will answer seriously.
Best Regards.
#29
That's a serious error for a service manual, good thing that you questioned it. I think your manual picture shows plug "A" as the "check plug", not the more accurate "check/fill" plug.
CPLYONS
09-07-2015 07:19 PM
Clarence Willie Mays
09-06-2015 10:30 PM
carl viking
09-05-2015 05:31 AM
