CEL continued...
Old Feb 13, 2007 | 08:39 AM
nooB5's Avatar
Default CEL continued...
So, I got a CEL yesterday, and then my car went into limp mode(?) - all the dash display showing the different gears all lit up like a christmas tree, and serious loss of engine power.
This morning, when I started the car to go to autozone to get my codes pulled, the display was back to normal, with engine power back to normal.
Codes were:
P1127
P1129
P0411
P0103
can anyone translate these for me in layman's terms? Why the loss of power?
I really am starting to have a love/hate relationship with my car.<ul><li><a href="https://forums.audiworld.com/a4/msgs/2662409.phtml">Yesterday's symptoms</a></li></ul>
Old Feb 13, 2007 | 11:02 AM
Ertman's Avatar
Default get a vagcom, log block 003
an easy search of the archives revealed
P1127 - Bank 1, too rich
P1129 - Bank 2, too rich
P0411 - Secondary Air Injection, incorect flow detected
P0103 - MAF, implausible signal
sounds like you MAF is dead or dying. Get a VAgcom and check block 003 @ idle, MAF readings should be between 2.0 - 4.0 g/s. I bet that it is reading around 5.0-7.0 g/s at idle.
Old Feb 13, 2007 | 11:05 AM
sjthomas's Avatar
Default STFA...
all these codes are well documented in the archives.
The first two indicate you're running rich in both banks 1&amp;2.
The third indicates a secondary air injection leak of some sort.
The fourth indicates a MAF sensor problem (signal too high).
Replacing your MAF sensor may solve all these issues, it may be telling the engine it's taking in more air than it is = rich. I'd check your secondary air injection system for leaks also, just to be safe.
I don't have first hand experience with any of these but the 3rd (and I've a 1.8T), so all that info is available if you just search.
Post back with what you find out.
edit- Ertman beat me to it. Damn my slow typing and weak searching skillz.
Old Feb 13, 2007 | 11:20 AM
nooB5's Avatar
Thank for your time guys! I will STFA more often! - Cheers
bA8
May 29, 2007 02:40 PM
Felk_2.7T
Dec 3, 2005 11:39 AM
unc99206
Nov 14, 2005 06:00 AM
Justin517
Aug 3, 2004 08:14 PM
the senator
16
Jul 9, 2003 01:35 AM
