Cluster fail speedo twitch at 0 fix!!!!
After 6 months i have gotten fed up with a broke cluster and i finally sat down and had my heart set on fixing it and so i succeeded very simple actually. You have to take apart the complete cluster n take the speedo and fuel gauge off you pull the needle for the speedo off and under that is a little tiny case with the needle for the speedo under this case there are 3 sprockets very small about 1 cm big each and on the pin fir the speedo there is a little coil with a end on it that lays in a certain spot the end comes off and cause the speedo to go crazy put this back in place and your set to go I will post a DIY as soon as I can
ar design
9
04-14-2007 10:40 AM
ATH
01-29-2005 03:49 PM
FinnTT
07-31-2003 06:22 AM
