Correct tire pressure - what a novel idea!?
Checked my tires yesterday and they were all 5-7 lbs underinflated. Major improvement with the tires at 42psi - rolls better...easier to shift smooth.
Between that and the 3/4 qt. low oil level (I cant allow myself to believe the break in/burn theory), I wonder how thorough the pre-delivery inspection was...
Pre-delivery inspection...
You say that the tires were underinflated by 5-7 psi and you now have them at 42? That implies that the car was delivered with 35-37psi in the tires; isn't that within the factory-recommended range? I mean, preferring a higher pressure is fine, but I don't think that's a delivery inspection problem.
My '96 2.8 drove *really* hard at first, until I got out and checked the pressure and found it was delivered at 50 psi; they had apparently forgotten to reduce the shipping pressure to one that was driveable. Now *that* is a delivery inspection problem.
And yes, while I can't speak for the 30V, I can say from experience that the 12V 2.8 can go through a lot of oil during break-in.
-dan
-dan
Gas door says 42psi. I'm sure 35 is within the acceptable...
...range. I was just a little surprised that they were underinflated, and how much of a difference it made. Sounds like you had a very similar experience!
Im still on the fence about the oil....but it will be interesting to see if it burns more (?) oil between now and the 5K service interval.
Ming rings in Minn
16
10-16-2007 08:24 PM
UrSoccer_mobileĀ®
11-19-2003 08:02 AM
