curiosity... PC16 K04'd 1.8tqms vs. 330ci
330 loses...0-60 would be close, but it the a4 will have a better 1/4 time.
0-60 will really depend on the drivers for both vehicles. on the highway I beat up on 330s. i'm running the PC16 file.
honestly i used to beat those when i was stg2+ (fmic, TB chip) those things are so damn heavy
have driven quite a few also and was supremely unimpressed at how sluggish they feel. on the other hand dont hit the twisties with one! they handle incredibly well...
stg 3 now they are just fat *** baby seals... i dont even bother with em...
have you dynoed your car with the PC-16 set up??
what kind of numbers did you put up if you did. im really looking into basically exactly waht you have, PC-16 file chip, K04-015, TT injectors, adj FPR, and FMIC. Also if you dont mind sharing, how much did you get your PC-16 file for??
nope never dyno'd. so i dunno...i have a GTECH PRO COMP...
and that said 215awhp/264awtq, that is the only log i have of my power. someone with the same setup on AW dyno'd 217/274...actually that might have been J31 software. did another run and i got 214/262. so i think i have my gtech dialed in close.
PC16 was a reflash so it was 20 bucks at my local tuner for a reflash. once you have a GIAC chip...reflash is 20 bucks at their shop. i've tried both files PDK16 and PC16...i like the PC16 better.
absolutely...aggressive file..needs the cooling of FMIC to keep the timing up.
the car is consistant ever since i put the FMIC on...cuz i hot days...heat soak and set in easily...when i put the FMIC on...it was more consistant power there. Not too mention it would last longer. the tiny side mount IC can't hang in the summer.
and the file was written specifically with an FMIC on. FMIC was one of the best mods i could have done.
(not a) $leeperA4
Performance and Tuning
06-08-2003 11:59 AM
quattrostud908
01-25-2003 11:05 AM
T-28-Quattro de VT
09-06-2002 09:30 PM
I have an MTM exhaust, and thinking about getting the MTM chip, but I am also in the works of gettin
Thrawn
08-09-2001 06:44 AM
