DC area folks - suspension questions
Does anyone in the DC area have APR roll-control or eibach set-ups? How are they for driving on DC streets? My car spends much of it's life in DC.
I have stock sport set-up and want to keep a pretty compliant ride but cut back on brake dive and lower the car a bit. Suggestions?
Also, anyone have non-OEM clutches to recommend? AWE is apparently good but maybe too expensive for me....
Thanks!
Thanks!
A lot of people apparently keep their Sport Pkg Springs and buy Neu/Bil Shocks will allow you to
adjust the height a bit. I have Neuspeed Sports with the Neu/Bils and am happy with the ride although it is rougher. The best thing to do is to attend some of the area meets and see if someone will let you ride in their car to feel their setup.
Guest
Posts: n/a
Well... its a bit of a story...
As you may know, I'm getting a new used engine put in my car due to a broken spark plug. When the shop took my old engine out, they noticed that my APR clutch and flywheel and been worn down incorrectly, the outside was worn down into the bedding material, while the inside was almost like new. So I worked with APR, but since they discontinued those exact clutchs, they let me order one from SPEC at wholesale cost to them. Check out www.SPECPwr.com for the phone #. I should have it back on Wed... hopefully....
Let me know how you like the SPEC clutch. Their prices are very reasonable. S1 $349, S2 $419...
I want to upgrade to a S1 clutch when my stock one wears out. Maybe S2 at those prices but that will probably be overkill. Thanks...
Additional info:
Stage 1(part number SA241) up to 300 ft lbs
Stage 2(part number SA242) up to 375 ft lbs
Additional info:
jeebus21
12-18-2008 10:32 AM
MarathonMan
01-18-2003 02:28 PM
blingA4bling
02-15-2002 12:03 PM
Bill In SoCal
10-27-2001 10:21 AM
