DISABLING HEADLIGHT WASHERS
Old Mar 29, 2003 | 06:03 PM
tai's Avatar
tai
Default DISABLING HEADLIGHT WASHERS
I just installed my Reiger bumper today....looks great...but how do I disable the headlight washers??
Thanks for the help.
Old Mar 29, 2003 | 06:05 PM
ondo's Avatar
New Member
just put plugs in the hoses
Old Mar 29, 2003 | 06:07 PM
Bryans12v's Avatar
Default That would lead to leaks...
Just pull the power to the pump.
Audi2ptzero's Avatar
Elder Member
Default Only need to plug 1 hose, the same hose you disconnect
when you take the bumper off.
Old Mar 29, 2003 | 06:40 PM
unregistered user's Avatar
New Member
Default if you dont plan on using them again...
just take the reservoir out (and associated pump, wires, and tubing) below your coolant tank and throw it away, then plug up the tubing that feeds it from the main washer fluid tank
Old Mar 29, 2003 | 08:53 PM
Bryans12v's Avatar
Default I wouldnt throw it away...
I would sell it to me very cheap!
If you have some associated stuff for sale, email me.
Old Mar 30, 2003 | 07:45 AM
mdwsta4â„¢uroslut's Avatar
Member
Default where's the power to the pump?
when i checked the manual, the fuse that works for the headlight washers was also the same for like the AC and gauge cluster, so i said f**K it. i just plugged the one hose that you need to disconnect when you remove the bumper. get a bolt that fits real tight in there, wrap it with plumbers tape, put it in the tube, then clamp it shut with a clamp from home depot. if there's an alternate power source, i'd be interested in disconnecting it as well.
Old Mar 30, 2003 | 08:40 AM
Bryans12v's Avatar
Default Im refering to the connection at the pump.
You can just pull the power lead off of the pump and disable the washers, while they use different pump that the windshield, they work on the pumps pressure to pop them up and shoot, no pump, no headlujght washers.
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 30, 2003 | 09:15 AM
Member
got a pic of where the power lead is? never really looked at it before.
Old Mar 30, 2003 | 09:11 PM
PDXA4's Avatar
Default Which connection is this ? I would like to know...
I don't like my washers, but do not want to remove them...
Boldtk
Mar 12, 2015 05:49 AM
arndtc
Jan 20, 2004 06:12 AM
riceboy22
Jun 16, 2003 12:47 PM
Pal Sek
Feb 18, 2003 04:45 AM
Kent L
Apr 14, 2002 03:54 PM
