Does anyone clean the inside of their wheels?
Guest
Posts: n/a
Every time I wash the car...
I'm pretty **** about washing my car...I picked up a "Detailer's Choice" brush @ Pep Boys which is like a stiff plastic-sponge material on a stick. Works great for reaching back into the inner surface of the wheels. I also reach around the backside of each spoke with a sponge to clean that too. When I swap summer wheels/tires over to winter wheels/tires I take the opportunity to clean the wheels even more. I use bug & tar remover on the tar spots and either Meguiar's cleaner-wax or their clearcoat-safe metal polish on the outside surface. If I'm feeling really picky, I'll through on a coat of Carnuba wax also.<p>Washing my car is pretty time-consuming for me...between the wheels, washing in and around my roof rack, etc...I probably spend close to 1.5 hours washing/drying my car.<p>Andy Hedin<br>'97 A4 1.8Tqms, Wett 1.0 Bar, ABT Filter, Euro Headlights...<br>
Guest
Posts: n/a
1.5 hours cleaning your car?
Thats it?? And you call your self ****.<p>I recently spent 4 hours doing the exterior of the car, but of course I did all the door jams, under the hood and trunk, the engine compartment, and anyplace else I could reach without too much trouble. I even cleaned each slot in the grill seperatly. Once I was done, I was too tired to do the inteior in the same way, so I just quickly wiped it down. I could have easily spent all day cleaning the car if I would have started earlier. <p>I would say that a "normal" wash job - wash, dry, interior, etc, - is about 1 to 1.5 hours.<p>Matt
Guest
Posts: n/a
I did for about 3 weeks after I bought the car
Then I got tired off it. Too big of a hassle for a part of the car you don't even see. I used to use dishwashing sponge on a stick to get inside the tire. I would wash the inside if I had to take off the tire for any reason though.<p>Mark (98.5 2.8 QMS)
Guest
Posts: n/a
Re: Does anyone clean the inside of their wheels?
I wash the wheels inside and out every time I wash the car (along with the wheel wells, around the door jambs, trunk and hood openings, gas filler lid, etc.). To clean the inside of the wheels, I use a sponge drinking glass cleaner that can be found at just about any large grocery store. It is a sponge ball/star on the end of a plastic stick (so you can clean the inside bottom of tall glasses). It makes cleaning the wheels very easy, and it even fits between the front brake calipers and the wheel (and they are really inexpensive).<p>Dave M - '97 1.8tm
