follow up to previous post......double digit fuel trims
i previously posted on the S4 boards to get some opinions about adjusting my fuel with lemmiwinks. i was reviewing some 3rd gear WOT pulls and noticed my actual was always leaner than spec or requested. i then checked fuel trims at part throttle and found 13% add and .6% at idle. as recommend by the S4 boards i checked fuel pressure and it is a solid 4 bar. I pulled the air filter and pressure tested the system and had a slight leak where the PES TIP meets the turbo. pulled the TIP and put a light film or sealer on the flange face and reassembled. repressure tested and all was good to 15 psi. reset ecu and test drove. it showed a slightly lower part throttle add at 11.7%
any recommendations here gentlemen or should i just add fuel with lemmiwinks to correct the fuel trims?
heres the link to previous post<ul><li><a href="https://forums.audiworld.com/s4/msgs/2366058.phtml">previous post on S4 forum</a></li></ul>
I think mine is about the same
and I believe Mmart's car is as well. I saw a post from Todd@AWE about how around 10% is normal for S4's with larger injectors/turbos. I'm going to go out on a limp and say you're probably ok assuming your car is running code free and your 02 values under load are good as well.
I'm always sitting about 10-12%. While out of spec according to bosch, the car runs decent
...for a carburated volkswagen. My APR trims were never this horrible, PC16 is a pig when it comes to fuel and drivability. I've learned to live with it...
Firechicken
12-19-2007 10:16 PM
JazzGuitarist
06-27-2003 11:16 PM
Mike O.
Performance and Tuning
03-26-2001 09:48 AM
