Headlights, Turn Signals, and horn won't work!!!!
Hey all,
Yep...none of the above work in addition to my outside temp read out. Is this a fuse problem or a short somewhere. I checked all my fuses in the panel inside the car. Any ideas here, i'd rather not pay the audi dealer $70 / hour!
thanks,
Shaun
thanks,
Shaun
It seems to all be related to your steering column......
except for the outside temp. The headlights, turnsignals and horn are all switched from the steering column, so maybe the switches in the column are bad.
Try making sure your Key has sprung back all the way from "start" to "on".
That's what happened to me.
Made it so my temp, fan on Heater, turnsignals didn't work.
Let me know if that's it...
Re: Yeah, that was my prob, and I found out that on my 97, there was a recall on ignition switch
I checked out the key...it was fine. I also discovered on my lunch break that my horn doesn't work as a POS Honda cut me off! Guess its to the dealer i go!!!
Well i just called the dealer and they told me it is the ignition switch. I asked if there was a recall as igozoom97a4 said he had one, and they said no. So $420 plus tax...yay!
