how do i do this? (lighting)
<center><img src="http://www.squigly.com/rondosa/foggiesquestion.JPG"></center><p>i want to NOT have the circled lights on unill i use my turn signal. is there a way to do it without splicing...can a vag-com change it? i have no idea about lighting so any help would be appreciated
thanks
ps - i have searched but found nothing
thanks
you put electrical tape over the pins connecting to the harness. dont know which pin it is. there
are 3. one is ground, one is always on, and one...is the one that controls blinking
i just took out the pin on the corner bulb. my projectors are on
all the time and then the turn signals work but the corner lights arent on with the projectors. follow the wire in the harness to the correct pin and remove it.
Finally got around to wiring my city lights via relay, but where did you guys mount the relay? I....
Bill In SoCal
01-27-2002 09:18 AM
realdeal
11-09-2000 01:03 PM
