How do you get the lower rear control arm out?
Old 03-07-2009, 04:37 PM
dpulvino's Avatar
Default How do you get the lower rear control arm out?
I've tried loosening the rear subframe mount but even when I lever it down pretty hard I still can't get the bolt to slide out.
Also found out my ball-joint separator is not quite big enough to get the front lower control arm out.
So much for not too bad of a job.
dp
Old 03-07-2009, 04:48 PM
I was lost, now I'm found
myers1.8TQ's Avatar
Default Did you read over this?
https://www.audiworld.com/tech/wheel.html
Old 03-07-2009, 05:24 PM
Keeper of the Cash
Nate (ETKA+Scumbag)'s Avatar
Default BFH FTW *EDIT!*
Big Fvckig Hammer For The Win.
Pound the ball joint out. Who cares what it looks like if you're replacing it.
Old 03-07-2009, 05:36 PM
Guest
Guest
Posts: n/a
Default This is why people shouldn't listen to anything you have to say.
<Funny how he ends up editting his post 2 hours later...>
<a href="https://forums.audiworld.com/a4/msgs/2811721.phtml">Nuff said</a>.
Old 03-07-2009, 05:42 PM
Guest
Guest
Posts: n/a
Default Ok, take a deep breath....
You'll need to have the front of the car jacked up... jack stands on the unibody, not on the front subframe. You'll need to unbolt both of the large bolts that hold the subframe in where the DTS would mount, then carefully use a large prybar to pivot the subframe down enough for bolt to clear the fuel lines on the passenger side. One big reason not to just use a BFH like forum jockey Nate recommends. Then again, I bet he's never done control arms himself.
Anyway, it's almost easier with 2 people unless you can keep enough pressure on the prybar with one arm while unscrewing the bolt out of the subframe. After this you'll have a bunch more space to work with to get the balljoint end out. Use penetrating oil! Also, not that the subframe actually has 2 sets of holes that the lower rear control arm can get positioned into... make sure to put the new control arm into the same set of holes, or the alignment will be quite off. :-) Good luck.
Old 03-07-2009, 05:46 PM
Keeper of the Cash
Default Tell me Roger, why? Why? Why press that ball joint out if the arm is going to be replaced?
Hmmm?
What's your MAGICAL thinking?
Arrogant dick.
Old 03-07-2009, 06:01 PM
Audi4orce's Avatar
"forum Jockey Nate"?!?!?!? ROTFL
Old 03-07-2009, 06:12 PM
Allroady DungBeetle's Avatar
Default Because using a BFH for a job that can AND SHOULD be done with the right tool is stupid.
Using a BFH on those parts is a really great way to stress all the other components and possibly tweak the castings enough to cause problems either immediately or down the line.
It's just plain stupid to use a BFH if it's not needed at all.
Old 03-07-2009, 06:23 PM
Guest
Guest
Posts: n/a
Default Finesse over force my friend. I hope you never puncture a fuel line with your bludgening.
Go suck my arrogant .....
msgs/2878964.phtml
Old 03-07-2009, 06:34 PM
Keeper of the Cash
Default You're no where near a fuel line at the ball joint you know. I only used a 2 lbs mallet
and tapped the fitting out.
Or use a tie rod fork and pry it out that way.
Quick Reply: How do you get the lower rear control arm out?
