How much transmission fluid do I need for a 97 1.8TQM? I'm want to change to Redline today but...
Guest
Posts: n/a
I'm not sure how much I need to buy. Additionally, I don't know where to drain and then fill it up either. Can anyone help me out here? This cold weather makes the car a bear to shift for about five minutes.
Thanks,
Cy...1.8TQMS, APR, Neuspeed, BFG VR4, PIAA, Alpine, Clear corners and sides, Autometer, Sport grill...
Thanks,
Guest
Posts: n/a
Re: How much transmission fluid do I need for a 97 1.8TQM? I'm want to change to Redline today but.
CP,
It should take about 6 qts. Isn't it listed in your manual? I'm an Audi tech @ Lake Tahoe CA, I haven't had the complaint on any of the newer cars although we have made the switch on many older manuals. Must really be COLD where you are! The drain and fill should be on the left side (drivers) behind and above and below the axcel flange. You will need a special socket a 17mm 12 point with a hole in the center. I recommend you take it someone with the proper tools and experiance to do the job correctly for you and dispose of the old fluid. It's not a big $$ job, the Redline is the most expensive part.
Jake
944-100S
Audi 100 / A6 (C4 Platform)
06-21-2009 06:13 PM
Evil Buddha
RS4 (B7 Platform) Discussion
07-28-2007 04:06 PM
Roger A. Ellis
03-05-2004 05:40 PM
Carguy427
04-02-2003 08:37 PM
