It's all put together...but i get the check engine light..how do i access codes?
...through the climate control panel as per the article in the tech section? If so, i can't seem to get that to work. Press and hold recirc button....then press manual flow up or down and 1c should appear...right? I get nothing when i do that. I wonder what i forgot to reconnect...hmmmmmmmm
Andy
Andy
i found one thing disconnected...but i still get the CEL..help
...so i checked it again and found i forgot to connect the plug near the bottom of the radiator. plugged it in, started it up, still get the light. so i disconnected neg. terminal for a minute...then reconnected and started it up and i still get the light. is there another problem or can i not "clear the code"?? thanks...
Andy
Andy
dvsadversary
06-06-2002 05:50 AM
