Keep hearing that control arms are a problem...how do I know if I have this problem?
Re: Keep hearing that control arms are a problem...how do I know if I have this problem?
if you have a 98 or 99 then you have the problem.
or at least you will when you hit 30k 60k 90k etc..
sounds about right mine went at 62k mi. about 100K km.
as they start to go you'll here a loosness in front end, over bumps. if the sound turns into a groan it's time to change. $750 us. at dealer in 2000.
clunking or groaning in the front end is the usual suspect
Don't go replacing just because you hear there is a problem. Make sure they are actually bad. Don't go to the dealer if you don't have to. Buy a new set with grease fittings and have them installed by a local competent shop.
A4Driver
04-05-2000 10:55 AM
Kiho
08-28-1999 11:53 PM
Oggie
07-12-1999 07:11 AM
