Maximum speed '96 2.8 12V (problem?)
Guest
Posts: n/a
Hello,<br>I tried to see what would be the maximum speed and couldn't go faster than 110miles/hour. Not that I often need to drive at higher speed but it doesn't seem normal to me.<br>Any suggestions?<p>Thanks in advance,<br>Dima.
Guest
Posts: n/a
Re: Maximum speed '96 2.8 12V (problem?)
Not sure why, but you should be able to hit 130, I don't remember if it was my 93 90 csq or the a4, but I could go 130 is needed or was it 125, its beeen since last spring for my latest attmempt. After my wreck, I can no longer see any reason to drive that carelessly. Never know just who might pull out in front of you......
Guest
Posts: n/a
You should hit 128mph
Unless you are running 20 inch wheels or something, with the stock 16" wheel and 205/55 tires, you should easily hit 128 mph (never touched that 130 mark yet). Here, the engine will die - because fuel injectors will cut off and reengage when the speed sensor senses 125mph. There is a way to bypass the speed limiter. However, if you still have the stock H-rated tires, then do not do it, as you could blow them up under that heat and pressure and could be fatal. The A4 should hit 140, 141mph easy of a clear day. And like I said, there is a way to do it on the 12V, but you'll have to pay me to reveal =) ok just kidding. There are ways to fool the ECU and have the check engine light come on - thus disabling the speed limiter. What are those ways - hmmm, ok, that I'll have to keep a secret because I don't want you to start ripping sensors and vacuum lines apart. Speed limit is 70 or below. Be happy.
BigMouse
09-03-2002 11:31 AM
AlanG
01-08-1999 06:28 AM
