Need help with a Lean Code problem on an 01 AWM 1.8T...
Old Aug 15, 2006 | 06:31 PM
C5867's Avatar
New Member
Default Need help with a Lean Code problem on an 01 AWM 1.8T...
I recently had a check engine code P0171 System to Lean Bank 1. Then I started hear a pinging under light load and car definetly went into limp mode (aka a slug). I first started checking vaccum lines many of which I have already replaced to be on the safe side; unable to find a leak. Then I checked the MAF; cleaned the MAF cleared the code and the car was running great (More performance than before and no pinging). Then the light came back on after a few miles but I did not lose performance or hear any pinging. So, I continue to look for vaccum leaks. I can hear what seems to be the FPR hissing. Is there a possibility of an internal leak? Any suggestions from the forum would help me a ton! Thanks
Old Aug 15, 2006 | 07:50 PM
BLKPERL's Avatar
Default Do you have a boost gauge?
I had a leak at the brake booster
Did you check your dv?
Old Aug 15, 2006 | 07:59 PM
C5867's Avatar
New Member
No boost guage, no leak at the booster, DV ok
Old Aug 15, 2006 | 08:09 PM
Mr. Head's Avatar
Default Log the MAF block to verify the readings. Mine was reading extremely low (less than 100)....
It's supposed to peak at around 160 g/s...
Old Aug 16, 2006 | 10:41 AM
RSS's Avatar
RSS
Default Same car same problems Log block 032 if the second location is a high number its your MAF
my maf readings peaked at 96g/s
victor army
Apr 6, 2008 04:26 PM
CopperCounTTry
14
Oct 31, 2005 02:07 PM
Audone
Jul 6, 2005 06:36 AM
DavidST
Oct 31, 2004 02:33 PM
M3iRiSH
Sep 6, 2002 02:36 PM
