Need help......engine warning light
Old Jan 31, 2001 | 07:23 PM
stever012's Avatar
New Member
Default Need help......engine warning light
My wife just called and said her engine warning light just came on in her '99 A4. Told her to check the owner's manual, but she could not find an explanation for the light. Any ideas as to what triggers the engine light in an A4. Additionally, just had some body work done to rear of car and dealer had to replace A4 symbol. New one has a backwards 4, which the dealer claims is new for 2001. What gives?
Thanks.
Old Jan 31, 2001 | 07:31 PM
180q's Avatar
25 Year Member
Default Re: Need help......engine warning light
As long as the light is not blinking, and the car is running fine, the light should go out by itself within the next day or two.
Old Jan 31, 2001 | 07:36 PM
stever012's Avatar
New Member
Thanks for the info. Do you know what made the light go on and why does it go off after a few days?
Old Jan 31, 2001 | 07:39 PM
Matthies's Avatar
New Member
According to my manual (2001 MY) the engine light, in the speedo comes on and stays on it's the On Board Diagnostic System telling you something is wrong with the engine, WOW, go figure? It says if it's blinking it means it could be the catalytic converter. The manual, again MY 2001 p.116 here, says it's ok to continue driving at reduced speed, but take it to the dealer right away.
BTW my A4 is NOT backwards, and I looked at about 15 before choosing this one last weekend, not backwards A4's did I see.
Old Jan 31, 2001 | 07:40 PM
Ed's A4's Avatar
New Member
Try checking you gas cap. With the BMW's, if you gas cap is not on tight, it triggers the "check engine" light.
Old Jan 31, 2001 | 07:42 PM
Bill In SoCal's Avatar
Member
In some cars if you re-fuel with the engine running it will trigger the check engine light.
Old Jan 31, 2001 | 08:26 PM
dferr's Avatar
Junior Member
Had this happen on my A6.
It was a vacuum leak. Not harmful, but very nerve-racking until I knew what it really was.
Old Jan 31, 2001 | 10:38 PM
studlee's Avatar
happed to me with vaccum hose and bad gas
 Michael S. Palmer
sunset
Aug 29, 2004 02:40 PM
LenA3T
Audi A3 / S3 / RS 3
Jun 15, 2004 10:19 AM
Annapolis Dolphin
Sep 8, 2002 09:00 AM
LouisE
Mar 16, 2000 08:27 AM
Patrik
Sep 1, 1999 05:03 PM
