Need help with Fault Codes please (Just got VAG-Com Today)...
17544 Fuel Trim Bank 1 (Add) System too lean P1136-35-10---Intermittent
00526-Brake Like Switch-F 27-00 Implausible Signal
I recently repaired a broken vacuum line to the FPR and that made my CEL finally turn off. Is the first fault code because of that? Is it safe to just clear the first one?
What is the second one pertaining to?
Also my car is a quatrro model, tried to choose AWD on the control module but it doesn't respond, is that normal?
99 A4 1.8T Quattro, Tip
Second code registers when your foot is not on the brake pedal
when you pull the code. It's insignificant. Next time you can run a search through the archives on the 5 digit code, and you'll be able to dig a bunch of information up yourself.
PaulW
10
11-19-2008 06:42 AM
