NOW MY CAR WON'T START!!!
Car turns over, has battery, sounds like it wants to start but never connects. I thought I just flooded it this morning, so I went to work, came back and tried again and it just makes the noise of starting. Then one time it finally started, but it sat idle at around 1000, and I couldnt rev it up then it died. Help Anyone???
No...next time the car won't start...
put the key in the ON position (stop cranking the engine), and look for the CEL on the instrument cluster. If it's no on, there is a problem with the chipped ECU, and it has to go back to the tuner/APR. If the check engine light is ON, and you still can't start the car, then something else is wrong.
Do you understand what I'm telling you?
The CEL should be on when the key is in the ON position without the engine running. If you have a no-start condition, and you don't see that check engine light, it's the chip that's causing the problem.
Mike Atkisson
Audi Original "S" Cars
01-13-2007 07:28 AM
Slightly Leaned
08-02-2004 07:02 PM
