Ok..I THINK my 12v lead for my amp is messed up..anywhere else to wire up the 12v lead?
I can't get behind my head unit to check, i don't have the tools to get the symphony head unit out..and I can't seem to do it with nail files..
So is there anywhere else i can run the 12v lead off of? Even jsut temporarily.
The remote turn on..
I can't get behind the HU, and all the actual power wires seem to be connected right...but the LED light on the amp isn't coming on..and no power
It worked this afternoon..but the wires were exposed, so I moved them around a lil..I am HOPING i just pulled it loose.
You really need to get that unit out and check for exposed lines or...
else you could blow the power supply on the unit. You could also damage other components in your car. If your amplifier has a fuse (some are inside the amp some are outside) and that fuse is blown, then you have a short. Go to your dealer and have them pull the unit, they'll have keys. Or order a set, have it overnighted, and check the connections on Teusday. GOOD LUCK!
wildaman85
08-14-2006 05:10 PM
murray4225
07-20-2006 08:07 PM
UltraRoss
12-11-2004 12:51 PM
