only 23g/s at 5000rpm, is my MAF bad?? 2-3g/s at idle.
then that's probably about right....
hit the highway, cruise along and see what kind of numbers you get. You can actually unplug the MAF, and the ECU will use it's own set of numbers. The numbers should match very closely with the MAF plugged in, and with it unplugged. You'll probably have to clear the CEL afterwards though
you can also datalog RPM and MAF on a WOT run. The MAF should steadily increase, and then level off in the higher RPMs. You should see a max of around 170 g/s if you're chipped.
TTGram
05-22-2006 06:35 AM
Milpitas2.7T
12-07-2004 06:31 PM
DAP@EPL
Performance and Tuning
10
05-25-2004 06:30 AM
davematthews-S4
02-13-2003 01:10 PM
