Paint-like substance on hood of car...can't get it off....HELP!
Guest
Posts: n/a
Try using gas (No Joke)
I know that about a dozen or so will come on and say don't use gas, And I will agree with them, to a point. Gas is acidic, and will cut through paint splashes on the surface WITHOUT damaging the clearcoat finish, when washed within seconds after do so. Meaning have a hose, soap and water ready to clean off the surface you have just gassed.<br>I have done this multiple times on a black car without any problem. What I do is a take a rag, pour a little gas on in and then rub the area with the problem. I then immediately take soap and water to the surface and take all of the gas off. I will wash the surface atleast twice. I will then Wax the area, and the car in general.<br>I know that this advice will have a lot of detractors, but it does work if you do it correctly and don't allow the gas to sit there for to long.<br>Flame suit is now on.
Guest
Posts: n/a
Milder suggestion: WD-40
SI has a good suggestion. Another method is trying Wd-40. I have used this on several different types of spots successfull. <p>Spray on spot, let it sit for a couple of seconds, then try rubbing out. After completion, washt eh esection and apply wax. WD40 shouldn't hurt paint but it sure attracts dust/dirt.
lskolnick(original)
Auto Detailing Discussion
02-03-2003 06:12 AM
BSOD
01-13-2003 10:46 AM
HSJ
09-25-2001 05:54 PM
10 coats of Zaino on hood+Black paint+summer sun+engine heat+rain= water spots on hood in the Zaino!
BrianN
06-01-2000 08:32 PM
Nogaro
05-30-2000 03:37 PM
