On pass side what bolts do i loosen or lower the lower sub frame for lower rear control..
<center><img src="http://pictureposter.audiworld.com/32880/lower.rear.jpg"></center><p>arm replacement.. i can almost get the new bolt in but i need about a halfc inch or so..
Thank you~~ i had to cut the bolt out with a hack saw..here is a pic to help thanks~~~
The three bolts on the triangular plate...
to the left of the hand in the picture. Take the two smaller bolts (to the rear of the car) out first and then loosen the larger one to lower the subframe.
i read your write up thanks for the photo.. did you have to lower your sub frame to get the bolt in?
i dont remember you mentioning it when i read your tech but that was over the weekend and alot has happened since then!.
THANKS!!!
THANKS!!!
NorCalS6
12-07-2007 05:45 AM
timsias
07-06-2006 12:13 PM
pointby
11-29-2004 05:05 AM
xdriver
06-24-2004 05:08 PM
