Power steering problem....
Old Mar 9, 2005 | 11:24 AM
inkdrummer's Avatar
New Member
Default Power steering problem....
My 1998 A4 2.8 quat is going through power steering fluid like it's going out of style. I do see a bit of fluid on the lower engine cover plastic. Is there an overflow coming from the P/S reservoir? Could this be a pump issue if I find no actual leaks? Thanks!!
Old Mar 9, 2005 | 11:28 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Check the rubber boots on the tie rods..
Old Mar 9, 2005 | 11:31 AM
por911's Avatar
Default Re: Power steering problem....
The leaks are usually from bad crimp connectors(hoses going to p/s fluid expansion tank), bad hoses, and or steering rack. Remove the belly pan and have a look. There is no overflow to the expansion tank. Doubt its a pump issue. Check inside the boots on the steering rack. When the rack starts to leak the fluid fills the boots.
Old Mar 9, 2005 | 11:42 AM
inkdrummer's Avatar
New Member
Thanks! I am checking it out tonight...the price of that fluid gives me good incentive to get on it.
Old Mar 9, 2005 | 01:29 PM
por911's Avatar
Default If you think thats bad.....
What till you see the price of a reman-steering rack and the labor it takes to install one.
Old Mar 9, 2005 | 02:12 PM
Im@wesome~ out!'s Avatar
Probably the rack.... just had mine changed... search this topic.. lots of stuff
Old Mar 10, 2005 | 06:00 AM
inkdrummer's Avatar
New Member
Default Re: If you think thats bad.....
Yep...it's the rack. I'm doing it Wednesday...damnit!!
noclueaboutA4
Rocky Mountain Discussion
Nov 8, 2010 07:53 AM
RA031326
15
May 29, 2008 08:18 AM
azndrunk74
Feb 2, 2005 05:56 PM
zeus1
Oct 26, 2004 08:20 PM
