Power window problem
Old Oct 21, 1998 | 11:33 AM
Tony O
Guest
Posts: n/a
Default Power window problem
I received my new A4 with a defective right rear window. The glass is out of control, when you operate the window down, it goes half way down and then reverses automatically and closes again. Or it chatters and oscillates. The dealer has now installed the third motor, maybe they should have realized by now its not the motor. The new motor(again) does the same thing.<p>You can also hear the relay/motor chattering on its own when you are driving.<p>Any help, idea what the problem is? The dealer/techs are at a loss?
Old Oct 21, 1998 | 12:07 PM
Bert
Guest
Posts: n/a
Default Re: Power window problem
Tony,<p>Does the window operate erraticly when you use the switch on the rear door or just when you operate it from the driver's door? Could be a problem with the switch at the drivers door. If the problem exist when using either switches, it sounds like a loose connection between the switches and the motor. <p>HTH,<br>Bert
allankennedy
Audi allroad
Jun 5, 2018 10:16 PM
BASARAB
Feb 20, 2012 05:36 PM
90v8quattro
10
Oct 14, 2005 01:05 PM
brent4kQuattro
Sep 17, 2004 07:34 AM
della
9
Oct 11, 2000 03:53 PM
