Problem with new ECS RA4 clutch...
#11
Well, supposedly ECS has sold 160 of these exact setups and have had no returns. The disk and PP are the OEM company, LuK, so I know the quality is there on that part. It looks like this one just slipped through quality control. I have a hard time distrusting ECS bc they seem to be a great company, but this is not the first time they have disappointed me, either. It took them 4 days after christmas to ship out a timing belt kit, resulting in me getting the parts a week and a half later. They are located 2 hours from me...
#12
One would hope that the vendor supplying a modified clutch assembly and flywheel took the time to ensure the pressure plate exerts sufficient clamping pressure on the friction disc and that the release bearing and fork are not maintaining leverage on the pressure plate springs. In addition, hopefully they considered the overall height and diameter of the assembly so it can be used with the original release fork.
The clutch slave cylinder actuating rod will usually seat itself within the fork 'dimple' once the driver presses the pedal.
Regarding the dual-mass flywheel: interestingly I have never seen one used with a friction disc containing springs. Was there a problem with clutch judder on the 1.8 motor or is that a modification an owner would make to their vehicle for softer clutch engagement?
Was this an entire package you purchased that included the flywheel, or is this the original flywheel that has been resurfaced? The machining on the flywheel is not very good, but it can be resurfaced to a smoother finish by use of a surface grinder. This appears to have been put on a lathe used for brake discs.
Take the flywheel and associated parts to a reputable machine shop and have the flywheel inspected to see if it can be refinished with a surface grinder. The machine shop can also give you an opinion on removing the hot spots from the pressure plate. The entire assembly should also be bolted together and measured for thickness to see if the flywheel and pressure plate have clearance inside the gearbox housing when the bearing and fork are installed.
http://www.ecstuning.com/Audi-B5_A4-...Clutch/ES5485/
Here is a picture of the flywheel on their site.
It is a cast stee flywheel. Spots that are machined down are to center balance it.
Here is a picture of the Billet Steel flywheel that is included in the Clutch Masters A4 1.8t 240mm Kit so you can compare it to the ECS cast flywheel.
If he has the surface machined down he also needs to grind down the lip(surface where the PP bolts down) so that the height between the 2 stays the same. If you only machine the surface down the amount of clamping load on the disk changes.
He can just check the stock clutch/pp/tb for height and check to see if the ECS kit is the same.
#13
#14
Does anyone have the specs on the height between the top of the FW and the contact surface for an S4 clutch? I just got back from the machine shop and he said everything looks like it should be clamping hard enough, but didnt have the specs on the S4 clutch for some reason to make sure. The guy seemed to think it could be something else like excess slop in the crank, which I have checked and it has no movement at all. Could it be something in the tranny, like the center diff or something?
Btw, sometimes when it was slipping really bad, if I put the clutch in and dead revved it, it would squeak at me when it had a slight bit of load when I blipped the throttle. Seemed like it wasnt disengaging all the way or something.
#15
None of those things are going to cause the clutch to slip. Either there is a issue with the clutch or the clutch just cant handle the power you are making.
The squeak could be the throw-out bearing. If the clutch isn't disengaging all the way you would notice it since the car would want to creep forward.
#16
Well I am only chipped on an s4 clutch, so power is not the issue. I did somewhat notice some noises if I'm coming to a stop and I go and put it in 1st with the clutch all the way in, but I dont notice it creeping forward any. I think thats somewhat normal for the transmission to do that, but the clutch does grab immediately when I start to let out the clutch with it all the way down to the floor. That almost makes me think its still grabbing at full disengagement, but doesnt make sense to not have enough clamping force then bc of too much stack height.
#17
Make sure you check the SAC while the PP is out. If it is not set correctly it can cause the clutch do engage right at the bottom of the pedal. The tabs should be sticking out of the openings.
#18
1 Post
Not always the case, I have even seen the slave rod pop right out of the fork because the rod end was not in the dimple.
It was a change Audi made on the B6 cars. I have one out of a B6 and have seen plenty other B6 A4 1.8t owners post up pics of their stock clutch showing that it was a sprung disk with a dual mass flywheel.
It is the RA4 kit which is a 240mm Cast flywheel and either a OEM S4 or RS4 240mm clutch kit and a S4 2.7t throw-out bearing. So the clutch is not going to work on the stock A4 1.8t dual mass flywheel which is only 228mm.
#19
Well I got it back from the machine shop. I had them resurface the contact area and match what they took off and then a little more on the outer edge as well. I'm hoping this will increase the clamping force. Now time to reinstall and hope for the best...
#20
So I figured I'd update since I have about 500 miles on it. It still seems to squeal and jump a little, but it is better. The only thing is the pedal feel seems to be inconsistent. It is definitely more grabby most of the time, but seems to take a long time to engage sometimes. I've replaced the slave cylinder and ordered a master cylinder so maybe thats causing the issue.
