Reverse lights aren't working. Failed inspection. $340 to fix.
#11
Quick search, I can't guarantee this is the right one: https://www.europaparts.com/reverse-...12919823f.html
My recommendation is a couple/few of things:
1) If the shop gave you a printed receipt, check on there and see if there is a part #...
2) Go on a site like ectuning.com or my favorite: fcpeuro.com, enter your cars information, then give the part a search.
3) If you feel comfortable with it (based on what I've read, read for yourself please) jack your car up, remove the driver side wheel, find that switch - remove it and check to see if there is a part # on it proper. If there is a part number on the switch you remove, you will know that it's the one you need.
The difference between the ones you find online are likely oem / aftermarket. OEM are generally more expensive and more reliable, the one the dealer will likely provide... but you can get away with aftermarket parts depending on the part. I've never dealt with a reverse light on my own car personally, but I do have several aftermarket other things on it. Mainly because I'm a broke college student; If I had the $ I'd probably go for OEM on most things... but just like name brand clothes, some things are just overpriced for the brand. As long as you do a bit of research, you'll be able to make an informed decision.
Word.
Word.
Backup Switch - 066-200 NS380989 - $235.30
A google search of that code does not yield any results.
#12
I entered my vehicle information and did find a backup switch from fcpeuro.com
https://www.fcpeuro.com/products/aud...fae-012919823f
#13
I recommend purchasing from FCPeuro, if for whatever reason the part is incorrect, they have a fantastic new return program, although I believe that is the part you need.
This is as far as I go.
Take care, emd023.
#14
Sorry to resurrect an old thread, however, I wanted to check my fuse box before I purchased this back up/reverse light switch. I have found the fuse list online but I don't see any reverse/back up fuse in the list. Why is this? Would this use the same fuse as the tail lights?
Fuse box diagram and amperage list
Fuse number – Description – Fuse Amperage
1 – Heated washer jets – 5A
2 – Turn signals flasher unit – 10A
3 – Headlight washer, illumination of glove compartment, engine compartment, climate control, automatic transmission, instrument cluster – 5A
4 – License plate light – 5A
5 – Instrument cluster, seat heating, test connection for cruise control, bulb monitor for auto-check control, Automatic transmission display, switch lighting, mirror switches and actuators, airbag warning light, outside temperature indicator, Climate control – 10A
6 – Central locking system – 5A
7 – Anti-lock brake system – 10A
8 – Empty
9 – Mirror heating – 10A
10 – Empty
11 – Cruise control (automatic transmission) – 5A
12 – On board diagnostic system – 10A
13 – Brake lights – 10A
14 – Interior lights, reading lights, anti-theft alarm system, vanity mirror – 10A
15 – Instrument cluster, power windows, climate control, automatic transmission – 10A
16 – Anti-lock brake system, Anti-Slip-Regulation – 5A
17 – Heated door locks – 10A
18 – High beam right – 10A
19 – High beam left – 10A
20 – Low beam right – 15A
21 – Low beam left – 15A
22 – Tail and side marker right – 5A
23 – Tail and side marker left – 5A
24 – Wiper and washer system – 25A
25 – Blower for heating, climate control – 30A
26 – Rear window defogger, mirror heating – 30A
27 – Rear window wiper – 15A
28 – Fuel pump – 15A
29 – Engine timing – 20A
30 – Sun roof – 20A
31 – Tail lights, cruise control, automatic transmission – 15A
32 – Engine timing – 20A
33 – Cigarette lighter – 15A
34 – Engine timing – 15A
35 – Trailer receptacle – 30A
36 – Fog lights – 15A
37 – Radio – 20A
38 – Luggage compartment light, central locking system – 15A
39 – Emergency flasher – 15A
40 – Horn – 25A
41 – Anti-lock brake system – 25A
42 – Empty
43 – Empty
44 – Seat heating – 30A
8 – Empty
10 – Empty
30 – Sun roof – 20A
37 – Radio – 20A
40 – Horn – 25A
42 – Empty
43 – Empty
MadScientistS4
04-12-2009 01:01 PM
Wren90q
04-28-2003 12:24 PM
