schematic for manually controlled electric fan...
as soon as i get the parts i can do this up
<img src="http://www.modifieda4.com/images/manual-fan/manual_fan_schematic.png">
Just my .015$ but I'd run a separate circuit with a 35amp fuse, a separate thermostat,
preferrably an adjustable version and its own relay for an EFK. The a/c fan/fan relay isn't the place to get power for an EFK IMO.
ditto. adjustable temp switch with my SPP EFK. <$30 from Jegs/JCWhitney/Summit Racing
<center><img src="http://pictureposter.audiworld.com/10901/efk_adjustable_temp_switch.jpg"></center><p>
I mounted it under that PITA to put back on cover for the power steering fluid reservoir, tstat is in the fins of the rad, and it's powered by 75X under the dash with a ground near where its mounted.
I have it adjusted right were it'll shut off while driving, but kick on at idle (when up to normal temps), which is definitely lower than when the a/c fan kicks on. I'm sure it's later than with stock parts, but not by much.
fyi, my schematic is for manually controlling the existing electric fan.
basically i will be able to push an OEM button on the dash and have the fan come on...great for cool downs or in between dyno/drag/auto-x runs.
btw, im not a "fan" of EFKs. :P
sugaryling
17
08-21-2007 05:17 PM
Kingttr
07-31-2007 11:03 AM
in2audi
05-20-2005 05:27 PM
darkhelmet
Audi 100 / A6 (C4 Platform)
01-15-2004 06:45 PM
