Someone HELP please! Name that sound!! Major help needed...
I recently put in a clutch (Southbend stage 3) and in about 200 miles it started to make this sound... Well, it doesn't really do it all the time... It happened at about 200 miles and then every 100 miles or so after that until my 800 mile mark... It is starting to do it more often now... 900 miles total on it... It will start very faint and only when the clutch is pushed in, then a few seconds later after pushing the clutch in and releasing it, it will get worse and another push in/out will make it worse until it is constant... Seems almost tempurature dependant but I know it isn't... Doesn't happen on cold starts at least. Also, only really seems to happen when I come up my driveway after comming home from work... Driveway is about a 12% grade...
<a href="http://members.***.net/poopoopoochoo/damnclutch.mpg">clutch noise 1</a>
<a href="http://members.***.net/poopoopoochoo/ihateyou.mpg">clutch noise 2</a>
30+ views and no help? I was hoping for someone to at least say boo!!
Watch the boos roll in now in the future posts...
Sorry for the impatience, I just need to figure this out soon...
Boo!!!
are you absolutely positive your flywheel is torqued down. Something sounds very loose, and my guess(non-educated of course)is that a bolt or something came loose and is tearing your clutch to hell. Personally, I would not drive it untill you find out for sure.
eigenvector
31
11-10-2006 12:45 PM
4Rings::G2 boosted::
Mid Atlantic Discussion
08-21-2006 01:30 PM
Patrick B.
07-06-2000 03:01 PM
