squeaky control arm
Old 05-18-2004, 08:24 AM
FishMan's Avatar
Default squeaky control arm
Does anyone know of an easy way to identify exactly which control arm is squeaking?? Also, I plan on replacing the culprit myself. I did the timing belt and water pump and I'm assuming it can't be more difficult than that job. Any advice would be greatly appreciated.
Andy
Old 05-18-2004, 08:34 AM
CK:1.8T+Rabbitâ„¢'s Avatar
Default I'd just go all out and replace them all if I were you.
start with the upppers anyway. But you may want to wait and see how this recall thing pans out.
Old 05-18-2004, 08:43 AM
DoubleClutch's Avatar
Default is this a DIY project
My control arms just started squeaking as well. Grrrrr
Anyway, I was just checking out ECS's full control arm kit that includes everything.
http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?make=Audi&model=B5%20A4&s ubmodel=Quattro&engine=1.8T&category=Suspe nsion
Except for the alignment at the end, is this a DIY project?
How much can I expect to pay in labor to get this kit installed and the car aligned?
TIA
Old 05-18-2004, 08:44 AM
Default YSATI
<ul><li><a href="http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?make=Audi&amp;model=B5%20A4&amp;s ubmodel=Quattro&amp;engine=1.8T&amp;category=Suspe nsion">http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?make=Audi&amp;model=B5%20A4&amp;s ubmo
Old 05-18-2004, 08:46 AM
New Member
sl1200's Avatar
Default Second.
You'll get a better deal purchasing all 8 (see ECS Tuning), and it'll be easier in the long run to just tear the whole suspension apart only once. If you're anywhere near 100K you might think about doing wheel bearings as well if you have access to a good hydraulic press and they haven't been done yet (you'll have the hub assembly off anyway...that's the bulk of the labor for the wheel bearing job.
Old 05-18-2004, 08:48 AM
New Member
sl1200's Avatar
Yes.
Tie rod ends might be a good thing too.
Old 05-18-2004, 08:53 AM
YALP
Old 05-18-2004, 09:00 AM
Head Cat Herder
Kris Hansen's Avatar
Default The control arms are in fact much more physically demanding than the WP/TB job...
the uppers require taking out the shock assembly, the lower rear requires dropping the subframe in most cases, the lower front requires changing out the sway bar link. Dont' forget to only torque the inner bushings under load..
Old 05-18-2004, 09:01 AM
Head Cat Herder
WTF?
Quick Reply: squeaky control arm
