stalling
Old Dec 24, 1999 | 09:25 AM
Michael
Guest
Posts: n/a
Default stalling
I have a 96 2.8QM and recently, it has had a stalling problem. When I come to a stop, the rpms just drop and the car stalls. I thought that maybe I had too many things running at the same time (radio, seat heater, heater) but when I turned these off, the car still stalled.
I thought it was a bad tank of gas so I re-filled with high octane but it didn't seem to help.
This doesn't happen all the time, but when it does, it occurs several times in a row.
Any ideas?? Is my timing off? Do I need to have the idle speed adjusted?
Thanks,
M
Old Dec 24, 1999 | 10:47 AM
Bob
Guest
Posts: n/a
One word - IAC or ISV - Idle Stablizer Valve (another Audi known problem)
Old Dec 24, 1999 | 12:23 PM
Mike
Guest
Posts: n/a
Default Re: One word - IAC or ISV - Idle Stablizer Valve (another Audi known problem)
Thanks Bob... can you give me a few more details??? Is this a recall problem?? Is it a complex thing to repair/replace (in other words, is it going to cost me a fortune!!)
Any help would be appreciated!
M
Old Dec 24, 1999 | 01:42 PM
Bob
Guest
Posts: n/a
Unfortunately, it is not a recall problem. Audi has had issues with their IAC/ISV since the early 80's. They tend to get carboned up. If you feel adventurous, you can remove the valve and clean it out with Techron or WD40. Typically the valves last 2-4 years. When they start to go, you will have idle problems sporatically, and will get worse with time. I've had my valve replaced twice on my 96. Audi's design has not changed since then.
Search the archive, because I remember that someone posted a picture and instructions.
Good luck,
Bob
96 A4QM
Old Dec 24, 1999 | 03:15 PM
Mike
Guest
Posts: n/a
Bob..thanks for the quick response!!! How much did Audi charge to replace the valve?
M
Old Dec 24, 1999 | 05:39 PM
Bob
Guest
Posts: n/a
Luckily it was free... I snuck it in before the Audi Advantage expired.
Old Dec 24, 1999 | 06:18 PM
Mark H
Guest
Posts: n/a
Replace the Spark Plugs.
Mr.D-'97 A4q 12v
Mid Atlantic Discussion
Nov 14, 2006 06:33 PM
craudi
Sep 13, 2005 07:45 PM
freezing4
Jan 29, 2004 10:06 AM
jec6
Dec 22, 2001 04:56 AM
kwt
Misc. Models Discussion
Jan 9, 2001 10:33 PM
