stereo install problems
Is anything sith the headlights wired through the head unit? Any ideas would be appreciated.
You might be pulling power off of the power line into the lamps... .
Post some more info about what the wiring is like.
2. If they don't turn on, does the car still beep at you if you have the lever on and try to leave it on when you exit the car? If it doesn't, you may have accidently severed the lever's line when you cut the speaker or line out wires.
3. Try disconnecting the power line to the amp and see if the lights come back on. I doubt this will do anything if all else in your car works, but it's worth a shot.
4. Make sure you haven't grounded out the lights (or have pover running to the ground line of the lights) with some exposed wire somewhere.
As always, good luck!
