Stupid manual...
Stupid manual...
Hey all,
Just bought my 2000 A4TQM and am having a hard time shifting it into first and second when it is cold. I was going to start by putting synthetic oil/fluid in the trans, but the stinking owners manual doesn't say beans about what to use.
Does it use ATF or gear lube? What type or weight?
Thanks
Thanks
Re: I used to have the same problem, it virtually disappeared when I installed a Neuspeed Shortshift
Really? This seems more like a lubrication problem.
I was going to install a short shifter anyhow, but the cash flow is a bit short right now.
I think it's not just a lubriccation problem, but also the accuracy of the shifter......
the Neuspeed is a lot tighter, much less slop. I still notice a little bit more resistance when it's cold, but it's not nearly as bad.
AudiWorld Expert
are you sure about that? ....
I read on the S4 forum that Audi only started putting in synthetic tranny fluid for 2002 model year S4. I don't know whether they started doing it for all Audis or just the S4. In any case, I doubt the A4s before 2002 have been filled with synthetic tranny oil from the factory.
