Is there a way to take the cupholder part of the dash apart without removing the stereo?TIA
I did it in my 1999.5 but don't know for sure about newer models...
you just need to take the trim piece off where the cupholder is (held in by some metal tabs), then you can slide the cupholder out by flexing the tabs holding the cupholder in. It is pretty easy to do once you get that top trim piece off.
99.5 has the same dash as 2001+, so I assume that its the same....:)
does your dash look like this<ul><li><a href="https://forums.audiworld.com/a4/msgs/318336.phtml">https://forums.audiworld.com/a4/msgs/318336.phtml</a</li></ul>
i used a screwdriver wrapped in a rag so not to scratch.
there are 6 snaps 3 top 3 bottom, so pry gently behind each one so not to break em. the cupholder itself has metal clips that are visible.. i think 2 small screwdrivers/ nails/ whatever took care of those if i remember correctly.
WMi_S4
20
12-08-2008 01:24 PM
Razor1973
08-27-2004 06:39 PM
2low4snow
06-24-2004 07:19 PM
SC^S4
09-23-2001 09:55 AM
