Transmission Problems..searched here is what i have. any ideas ?
Not sure where to start checking. I have read in forums this may be a wiring problem. I am an electronics technician but never on a transmission. Any help would be appreciated
Fault Codes:
P1137 - man specific code
p0116 - Engine coolant temp range performance Problem
P0741 - Torque converter Circuit Performance or Stuck off
Fault Codes:
Well...
I don't know the first code, but the 2nd looks
like your coolant emp. sensor, which fail often
and are easy/cheap to replace and practically a maintenance item on these cars.
The torque converter problem could be something as simple as a clogged/stuck solenoid, I think there are as many as 5 or 7? Best to get it checked by a pro. Have you done a pan drop & fluid change?
Re: Well...
yes recently ... the pan had to be replaced so when i replaced it it was filled with new fluid, filter, gasket. Ran fine for about a week then started this. Doesnt seem to be getting worse but cant possibly be good not driving it now.
wcostello
VAG-COM Discussion
03-07-2008 04:41 AM
elboy0712
02-28-2007 02:59 AM
VA_Esfour
04-20-2005 01:23 PM
