Trouble Code P1136
Old Oct 31, 2005 | 05:38 AM
FishMan's Avatar
Default Trouble Code P1136
I'm still throwing code P1136. So far, I have replaced my MAF, all vacuum hoses, and my pre-cat O2 sensor. The car runs like a top and throws the code after about 30 miles of driving. Any clues????
Old Oct 31, 2005 | 05:49 AM
4Rings::G2 boosted::'s Avatar
Banned
Default "Long Term Fuel Trim Add. Fuel B1 System Too Lean."
The additive trim error means it's happening at low RPMs, around idle. Being lean most likely means that you have a vacuum leak somewhere and are sucking in unmetered air. Check all lines and seals, around throttle body and intake manifold.
Old Oct 31, 2005 | 06:06 AM
BigEd's Avatar
Member
Default What 4Rings said. And build a pressure tester (search for info) to locate the leak(s)
it will save you money.
Old Nov 1, 2005 | 12:14 PM
FishMan's Avatar
Default Re: "Long Term Fuel Trim Add. Fuel B1 System Too Lean."
Thanks, I'll look for the leak.
nskeates
22
Dec 17, 2018 08:36 AM
CapitanMandingo
A4 (B7 Platform) Discussion
Feb 8, 2016 06:29 PM
cardiffkid
Oct 14, 2008 04:58 AM
S42000togo
Apr 30, 2006 06:50 AM
NoNonsense
Feb 27, 2006 02:35 AM
