Upper control arm bushing cracked, is it something to worry about?
<center><img src="http://pictureposter.audiworld.com/17039/img_0204.jpg"></center><p>
I don't hear the dreaded creaking, but the front end does seem to feel a little loose when I hit bumps at medium speeds, like 20 to 40 mph... Both side have this crack.
normal wear/tear issue... no need to worry till/if it penetrates completely thru...
and separates the inner sleeve entirely from the rubber. Yours appears to suffer a little separation where it's vulcanized/bonded to the bolt sleeve at the point where the rubber is at it's thinnest. If you replace these every time they look like this you'll be replacing them bi-yearly.
Additionally, cracked/separated bushings wont emulate the creaking sound we've all come to know & love as they're not under extreme pressure nor does rubber-to-rubber facilitate "squeaking." A dull 'thunk' maybe on sudden/abrupt changes in steering direction if they let go entirely but no squeaking as in a dried out metal-to-metal ball joint. Rubber is an excellent insulator and sound deadener... great at dampening squeaks, not transmitting them.
boonies
11-13-2008 05:09 PM
jjhurayt
04-19-2004 05:21 AM
Kinetic0510
04-17-2004 02:47 PM
Kinetic0510
04-13-2004 08:23 AM
