ways to get rid of CEL from test pipe? tried the diode thing
Old Dec 22, 2004 | 10:50 PM
rk1.8t's Avatar
Default ways to get rid of CEL from test pipe? tried the diode thing
in the o2 wiring and tried the simulator with no luck. any1 have other suggestions? thanks
Old Dec 23, 2004 | 12:46 AM
EGainer's Avatar
Default did you unplug the battery after you tried the simulator...
to reset the ecu so the CEL shuts off
Old Dec 23, 2004 | 05:18 AM
Justin517's Avatar
Default MIL eliminator
pony express mil eliminator, wires in line with O2 sensor get either a mazda or subaru one depending on the colors of your wires, mine works ok, i get an intermittent no signal code, think may be the wiring. next im trying 2 spark plug non-fowlers (basically spacers male threaded on one end and female on the other) stack em drill out the outer one to clear the dome of the sensor, put the O2 sensor in there and put the whole thing back in the test pipe, it moves the sensor out of the main stream of exhaust. there are a few posts on it, i guss it works quite well.<ul><li><a href="http://www.ponyexpressperformance.com">http://www.ponyexpressperformance.com</a</li></ul>
Old Dec 23, 2004 | 05:55 AM
BSCA4's Avatar
2nd on the spark plug non-fowlers. It works great on my friend car.
Old Dec 23, 2004 | 06:07 AM
nospek3's Avatar
Senior Member
Old Dec 23, 2004 | 07:12 AM
superv's Avatar
New Member
Default GPMoto
I know this works for WRX guys with test pipes. I also need to find a way to stop my CEL from coming on. Please keep me up to date on how your search goes.<ul><li><a href="http://www.rallitek.com/products.asp?ID=388&amp;PP=Y&amp;HB=&amp;ACC=&amp; SP=">http://www.rallitek.com/products.asp?ID=388&amp;PP=Y&amp;HB=&amp;ACC=&amp; SP=</a</li></ul>
Old Dec 23, 2004 | 01:11 PM
rk1.8t's Avatar
i cleared the codes before i tried the simulator, and back it came:-(
LarryF_in_Ca
Jun 10, 2019 07:28 AM
2.7allroad
Audi allroad
Oct 23, 2008 10:01 AM
Lilcarlson2
Apr 26, 2004 01:10 PM
lskolnick
Jun 10, 2003 03:39 PM
T-28-Quattro de VT
May 20, 2003 06:53 PM
