what did you pay for timing belt replacement?
A comment...
It usually runs about $850-1800(labor & parts), depending on whats done. The devil is really in the details. I spent about $600 just in parts when I did ours, but everything was done(rad, hoses, switches, tensioners, rollers, belts, mounts,pcv hose, etc.). That job, especially on the 2.8's is somewhat timely. Oh yes, rewarded myself with a nice glass of single malt and a cigar.
That's almost half what the labor charges would be here in WA...
With shop labor rates around $80-98, it adds up quite fast. I thought labor for a 2.8 waterpump/t-belt/t-stat was 7-8 hrs charge out. If your getting out the door for $50 an hour, consider yourself fortunate.
That includes no labor.
Parts only.
Timing belt stuff
cam and crank seals
cam covers
valve cover gaskets
cam adjuster seals
serp belt
water pump
t-stat
flush coolant
suction pump
green check valve
vacuum lines
air filter
plugs
etc.
Timing belt stuff
cam and crank seals
cam covers
valve cover gaskets
cam adjuster seals
serp belt
water pump
t-stat
flush coolant
suction pump
green check valve
vacuum lines
air filter
plugs
etc.
MoTTfied
9
03-01-2005 01:39 PM
BrianC72gt
12-03-2004 03:31 PM
Muhammad
Audi 100 / A6 (C4 Platform)
13
11-01-2004 11:52 AM
