What the heck is a ski sack?
I didn't want it but ended up with it anyway since I picked up a car from the lot. What is it? (picking the car up next week so I haven't actually SEEN it)
it's a vinyl sack inside the rear armrest that you can pass skis through (more)
to the back seat. It's there to protect the upholstery from getting wet (from water on your skis).
I'm getting some subwoofers put in tomorrow, so i'll probably cut the ski sack out and use the remaining hole for a "port" to get more sound into the cabin.
Hope that helps
Hope that helps
when u pull down the rear armrest....
you can unfold a sack that extends into the rear passenger area... you access it from the trunk, and if you have long objects that you dont want to damage the seats you use the sack... you can keep the rear seats in the ormal positio so you can have rear passengers, and ski/any other objects.
The hole without putting the seats down is the nicest thing ... wish I had it ... but then, I ski!
I have to put one "half" (60/40) down to fit my skis inside the car ... then I can only take 2 passengers and it is very tight.
