What is rooling the fenders?
Picture this...your fender lip is like and "L" shape, where the lower
horizontal portion of the "L" can potentially catch the tire, and get pulled down (deforming your fender, which is *no* good). You use a machine to carefully and gently bend the "L" into a narrow "V", buying a little more clearance between the tire and the body panel. The trick is bending the metal, without deforming the vertical part of the "L", and without cracking any paint.
Baseball bats are mentioned from time to time, but you should only use that if you cut your factory springs in order to lower your car.
s4wood
11-07-2004 05:34 PM
