When does the 1.8t AEB go into open-loop?
What parameters are needed for the AEB 1.8t go into open loop.
I know that at 2650 and below @WOT it's still in closed loop.
What makes it go to open loop? MAF reading?
I was also under the impression that when @WOT its gona be in open-loop, but mine doesn't go into open loop@wot when not in boost. I only noticed this when I drove around for a while then noticed my afr at redline was around 13.5. Then checked the trims and it was -10%.
Anyways I was able to lower when it goes into open loop@wot to 1700rpm by increasing maf voltage. I could probably make it go lower.
Background.
I just installed a 50trim and using a AEM FIC to tune it. Open loop part was easy, the close-loop part is whats taking up my time. Specially when decel to idle, engine just quits. It would be a lot easier if I messed with the o2 voltage, but I want to keep the closed-loop system for day-to-day.
50trim
630cc siemens
AEM F/IC.
Background.
50trim
630cc siemens
AEM F/IC.
pink shrimp
10-07-2008 02:22 PM
thewatcher101
08-13-2007 07:16 PM
BTCC A4
03-27-2004 12:02 PM
