window regulator cable
Anyway, to your point... all you need to do is get a pair of needle-nosed pliers and slightly bend the black metal on the window guide rail at the bottom, where it holds the cable to the rail... right where the little green cylinder shaped cable-holder is below the pulley. Check out the area near #6 in this <a href="http://pictureposter.audiworld.com/34747/front_window_lifter.jpg">pic</a> for the green piece im talkin about... anyway, bend the black metal so that its open enough to release the green piece. Then, you'll have all the slack you need. Adjust the pulley, and then put the green piece back where it goes and bend the metal back... be careful not to bend the metal too much too fast or you'll jeopardize the strength of it. Good luck!!!
