with an x-chip would you need a tt bpv?..
and are they pretty easy to install? i was thinking about having the dealer throw it in next time it's in, but if it's easy i'll just do it myself some weekend. btw i plan on going x-chip in feb or march when i'll have the funds.
thanks
chip
thanks
chip
You can use your stock one but it is prone to tear with more boost esp the x chip...I reccomend....
the TT one because its only about 30$ and it functions the same as the more expensive ones out. Its a very easy install as long as you have the car on ramps or something. Should only take half hour.
Definitley a lot stronger than the old chip
and I like it a lot. I am a little concerned about over-working the turbo and such, but I am rarely above normal boost levels so it shouldn't be an issue.
yep...going to try and get some logs soon to analyze
I rarely use more boost than I would with a regular chip, so I don't think it will be problematic. If it was a constant 20psi, regardless of throttle than there would be issues.
