3.0 coil pack clip removal question
Old May 24, 2009 | 09:20 AM
BrianN's Avatar
Default 3.0 coil pack clip removal question
What is the best way to remove the clip shown in the pic?
Thanks!
Old May 24, 2009 | 05:58 PM
mayhem100's Avatar
I'm stuck on the same issue. I think you have to remove the couple of torx screws that hold down the long orange rail and then pop all of the coil packs off at the same time. Then you can undo the coil pack you want to.
I'm hoping someone who has done it will chime in though.
Old May 25, 2009 | 11:17 AM
MikekiM@PureMS's Avatar
Former Vendor
The proper way is to use your thumb and push on the tab, shown in GREEN, in that direction. Then wiggle the connector off.
A second method which works if you have the access, is to use a very thin piece of metal, like a paper clip, and slide it in the slot shown in red, UNDER the little tab. Then wiggle the connector off.
Old May 25, 2009 | 05:10 PM
mayhem100's Avatar
So do you NOT have to unscrew the couple of torx screws that hold down the orange rail connecting the coil packs?
Old Aug 20, 2009 | 05:17 PM
ljschnel's Avatar
You need to remove the torx screws. Just the two on each side. You can use a hex key if you don't have that size torx.
jocru01
A4 (B8 Platform) Discussion
Feb 13, 2018 06:42 PM
mattarios2
Apr 5, 2007 01:24 PM
Bob Petruska
Dec 16, 2002 09:57 AM
crystalA4
Oct 14, 2002 10:45 AM
Steve in VA
Oct 8, 2002 05:41 PM
