Anyone ever have problems getting Audi's diag. computers to connect to their car? (long)
I went to my dealership today to get an engine coolant sensor replaced. The dealership's diag. computers couldn't connect to my ECU...I told them i was chipped...and they said they'd done a ton of REVO cars and had never seen this error. I'm not sure exactly of the error, but they wouldn't do the repair under warranty as they need a diag. printout in order to get reimbursed... so I told them I'd just do it myself. Pro-diag connects fine and shows fault codes...however when i try to clear the codes I get a "Protocol Error 8005". Now...when I first went to try to get an APR flash, they couldn't do the flash for whatever reason (the ECU wouldn't "take" the flash...then i went to get REVO, and they couldn't do the flash either, so we pulled the ECU and did it on the bench and the flash worked. So...I don't think this is a chip problem, as there were issues before the chip...
Has anyone had this issue or know what may be the cause? Basically if the dealer can't connect...my warranty for issues needed a diag. code is gone...only 9 months left on it, but nonetheless...
Thanks in advance...install write-up of B6 1.8T engine coolant sensor replacement (G62) to follow in the next day or so.
Sorry to hear, you should have fixed the ECU problem BEFORE you chipped, now it's hard to prove (M)
that the ECU crapped out on you BEFORE you did the chipping.
Hmmm... best bet if you really run out of options is to unchip it, go to another dealship and tell them to warranty it for you. or else you'll be stuck with a really great car but worth very little.
Sounds like you have bad EEPROM, but I would ask Shade Tree Software what the "8005" error means
because it sounds like a error code specifically defined by the Pro-diag software.
wantfryswiddat
09-21-2015 05:55 AM
Audi A6 2012 A6 3.0T Prestige (Atlanta)
QuickChange
09-04-2015 06:51 PM
