Audi B6 Quattro/FWD Fuel Pump Question
So unfortunately my fuel pump went on my A4 (FWD) and of course no where in town has one in stock and the fastest I could receive one if it was ordered would be a week. I really can't wait that long so I need some of your guys' knowledge.
My question is can I put a fuel pump for a quattro into a FWD? from what I have researched the fuel pumps are in slightly different places in the car but I couldn't find anything that said whether they are interchangeable or not. So if anyone knows the answer (or any advise about changing the pump) that would be greatly appreciated.
Thanks in advance!
Thanks in advance!
My question is can I put a fuel pump for a quattro into a FWD? from what I have researched the fuel pumps are in slightly different places in the car but I couldn't find anything that said whether they are interchangeable or not. So if anyone knows the answer (or any advise about changing the pump) that would be greatly appreciated. Thanks in advance!
As long as the tank is not full, the procedure is not all that difficult. On my B5 I had a difficult troubleshooting issue and had the pump in and out so many times that I could have it out in five minutes if I wanted to (trouble turned out to be broken wiring- underneath the wire insulation inside the tank).
The pump has a cylindrical white plastic body which provides suspension and noise control for the electric pump in the middle. The pump's cylindrical body is made to attach like a bayonet mount, rotating 15 degrees CW, to snap into place. By forcing it CCW, it will click and rotate 15 degrees to the removal position. Take a good look at the new pump; there will be groove on the lower rim of the cylinder which is the alignment mark. When installing, this will match a mark/line on the holding frame in the tank. You will actually see two lines on that frame close together; one for dropping it into place, the second mark being the latched position.
You may be able to rotate the pump body by hand, but often a couple of large crossed screwdrivers set against notches in the upper rim of the pump body will provide the leverage you need to unlatch it. Be sure to wear long rubber gloves, don't be reaching into gas with bare skin. A fire extinguisher nearby would not be a bad idea, and use an LED flashlight instead of any other kind that might spark.
betyouaint
A4 (B7 Platform) Discussion
10
01-01-2019 10:13 AM
snipun
07-21-2003 10:37 PM
UnderPressure
05-01-2003 09:53 AM
