A/C Issues
Old Aug 14, 2017 | 03:27 PM
MingA4's Avatar
Default A/C Issues
Been having some issues with my air-conditioning and I'm looking for some second opinions. I'm starting to think there's a clog somewhere in the system. My car is an 02 A4 with a 1.8T. Here's the story:
About a month ago I noticed when the outside temp was above about 85 farenheit, the AC would stop working and the ECON light would come on. Scanned the air conditioning module and it was throwing a code for "high pressure sensor signal too high". I had this problem on my last A4 so I replaced the sensor. Still have the same problem, still getting the same code. The compressor is functioning, the sensor is just shutting it off. I'm starting to think there's a clog in the system somewhere causing the pressure to build up. The orifice tube maybe?
If anyone has any input it'd be appreciated. Thanks in advance!
Old Aug 24, 2017 | 08:57 PM
elrodbaer's Avatar
Try blowing out the condenser with a pressure washer. A plugged condenser can cause high pressure readings. Just be careful with the fins. Good luck.
Old Aug 25, 2017 | 04:34 PM
Steamboat's Avatar
A few years ago I added refrigerant to try to improve my AC. In the process, I over pressurized the system and whenever the AC was on and the outside temperature got hot, the AC system would automatically shut down due to over pressurization. The Econ light would come on and not turn off until I cleared the code with VCDS. Each time it happened, I would vent a bit of refrigerant. Eventually, I vented enough so the pressure dropped to the point where I don't get the high pressure lockout any more.
m1964
Q5/SQ5 MKI (8R) Discussion
16
Dec 4, 2020 03:30 AM
tslag
Apr 28, 2019 04:59 PM
2002allroad
Audi allroad
Oct 18, 2017 03:02 AM
Q5Boostin
Jul 10, 2017 02:02 PM
SLE3PER
20
Jul 11, 2012 12:26 PM
